Cooling Performance
For cases capable of housing ATX or larger motherboards, we use our standard ATX case test kit, which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features. The CPU fan is fixed at 7V with an adaptor while the graphics card fan is locked at 70 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use Core Temp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
Lian Li PC-D888 (8 x 120mm fans; max speed)
SilverStone Primera PM01
SilverStone Raven RVX01
Cooler Master MasterCase Pro 5
Lian Li PC-D888 (8 x 120mm fans; min speed)
Be Quiet! Dark Base Pro 900 (inverted ATX)
In Win 303
No case - open test bench
Corsair Carbide Series 600C (max speed)
Be Quiet! Dark Base Pro 900 (max speed)
In Win 805 Review
Be Quiet! Silent Base 600 (max speed)
Corsair Carbide Series 400C
Corsair Carbide Series 600C (med speed)
Corsair Carbide Series 600C (min speed)
Be Quiet! Dark Base Pro 900 (min speed)
BitFenix Pandora ATX
Phanteks Eclipse P400S (max speed)
Be Quiet! Silent Base 600 (med speed)
BitFenix Nova
Be Quiet! Silent Base 600 (min speed)
Phanteks Eclipse P400S (med speed)
Lian Li PC-D888
Phanteks Eclipse P400S (min speed)
°C (Lower Is Better)
In Win 303
Lian Li PC-D888
In Win 805 Review
BitFenix Nova
